It is connected via cable?
Wireless?
Do other devices lose connection at the same time?
Ports open correctly?
Connected via router?
Does modem stay up?
Wireless
Binatone router, loses connection, when pc and live on, only if i attemt to to download on live,at times,, but sometimes just disconnects.
ports?
It might be that there is too much information coming into the router, what router do you have?
Run the xbox connection test, see if all of the options are correct. You might get a couple of moderate ones, which could be causing the problems (specifically to NAT)
Just had a look around, if that doesn't work, turn off your modem, router and console, leave it for a couple of minutes then turn on your console router then modem in that order
It;ll be through your router mate. Open up Firefox/IE and type in the routers ip address (usually 192.168.0.1 or similar, depending on what it says on the sticker on the bottom of the router)
thaks for all your help hilly,, apparently i have a one off router, was never meant for public use, damn friends and there gifts??lol,, anyway going to get a new compatible router, and have stuck the cable on for a bit,, no probs now, cheers
