I think the point is that he may as well use it if he has it. I certainly wouldn't buy a new card for it.tom_nieto said:I still don't understand why you're so fussed about the fact that it's software or hardware. It's going to be the same, it's not crappy!
no, you posted a thread about buying a soundcard. you didnt once see me recommend that x-fi for £150 did you?willhub said:Wht are you on about, but you dident listin to us, i couldent look into the future and know that si what your going to say, i got the soundcard BEFORE you told me.
Thats too bad, as i said.As i said, i did not just get it for DTS and Dolby Digital, i got it for all its fetures, now i DO NOT want to use SOFTWARE decoding seen as i got a card that can do it in HARDWARE.
hardware decoding and software decoding do the same thing. - decode a multi-channel digital source into a multi channel analogue feed that the soundcard can output to an amp/speakers.What is this about AC3 filter is i must use analoug connection, i am using analoug connection connected to the X-FI, and i was told to use hardware decoding i needed to use analoug as digital would only produce stereo.
now, since you have the z5500's, you should have the spdif lead hooked up and have the software set to spdif passthru and letting the speakers decode the signal.
I never said you couldn't. I dont know what you expect to gain from it, but there's no reason why not.So cant i use the hardware decoding on the X-FI or somthing?.
And remember, i did not just get it for DTS and DD5.1 i got it for all the other fetures so please stop saying i dont need this card, i do for other stuff and its going to last along time.
hardware decoding and software decoding do the SAME THING - decode a multi-channel digital source into a multi channel analogue feed that the soundcard can output to an amp/speakers.
Secondly, you only get 2 channel if your playing games, the card is perfectly capable out outputting 5.1 and more via digital for movies. now as i said in
Why do you only take notice when we say something you dont like :confused
Well if i only get 2 channel when playing games, why when i am in a game like ut2k4 can i only hear shooting from say the rear right speaker when someone is shooting at the rear right?
My second post already dispelled that myth. why didnt you read it?![]()
because your connected via analogue?
that was the first thing i wrote in the post so you would have seen it, but let's not split hairs over that shall we?willhub said:Becouse at the time you added that to your second post i was making a post and i did not see that.
well yea, i dont need to use optical and coax. But i want to use the decoder on the card to listin to DTS and 5.1 DD with analoug.
