Hi,
I have downloaded the trial vesion of XP 64 bit to try it out & it works fine apart from a few issues with my X-Fi card (it's the platinum fatality one). It doesn't seem to save any changes I make to any settings so I have to spend 5mins everytime I boot my computer up changing all the settings back (it starts in 2.0 rather than 5.1 which is really annoying).
Also, when I try to turn off or re-boot, I briefly see a BSOD but it's only displayed for a second then the computer reboots so I don't even have time to read what it says. It's annoying because to turn my PC off I have to hold the power button down till it switches off.
The wierd thing is the sound is fine, I can play games, play music & watch films/DVD's with no problems. I have downloaded the 64 bit XP drivers from creative.com & I even tried the new beta drivers last night but it made no difference. I know it's something to do with the sound card because I tried a clean install & still had the same issues. I don't have any of these problems with XP 32 bit either.
I'd like to buy the full version of XP 64 bit as I have 4gb of RAM, but if I can't sort these issues out then I'll stick with 32 bit for now.
Any suggestions would be much appreciated
Row_bot
Row_bot
