X-FI CD ISO
Suspended
17 Mar 2006
Anyone got a link to ISO of the X-Fi Music install CD? I'll be buying the OEM which comes without one, I believe you need it, you can't just install latest drivers from CL site?
thanks I guess it's this one?
(ISO) SB X-Fi series 438.89 MB
I'm downloading this from CL site, is it the latest set of drivers?
Creative Sound Blaster X-Fi Xtreme Audio software pack 1.04.0064 (27.99 MB)
XFAX_WBUP1_LB_1_04_0064.exe
Yeah use the ones from the site as it says they are an updated version of the ones on the CD.
when i had an OEM one, it came with the CD :)
I'm pretty sure you only need the CD if you want to install the bloaty skinned controls for each mode. The appropriate drivers from the website worked fine for my X-Fi XM.
