X-FI Configuration Help
17 Jan 2005
London, UK
Hey guys,
Just installed my new X-FI and I need some help. For some reason the configuration utility isn't working properly. When it gets to the rear two speakers it repeats the noise in the front to speakers.
i.e rear left - noise comes out in front left etc
Need a little advice on what to do, anyone else have this problem?
I've installed my audigy 2 many times and never got this problem :( Speakers are in sig,
King
Ok finally fixed the problem and thought I'd post the fix.
Basically it seems that when you have the logitech pro 5000 webcam chosen as ** default microphone, for some reason this turns down the hardware acceleration settings in windows.
Even if I set to full and reboot, it comes up reduced to normal. When I unplugged the camera I was able to keep the accleration as full.
This resulted in all the speakers working correctly with my X-FI.
Solution I found here:
http://forums.creative.com/creativelabs/board/message?board.id=soundblaster&message.id=61220
King :)
