- 15 Sep 2006
- Liverpool
Other than a box, what do you get in the retail version of these sound cards?
Thanks.
Thanks.
Jokester said:Driver CD and I think a case badge as well.
Jokester
H2F Scott said:I heard there was some diver issuses with the OEM version. Although I don't see how if it's the same disk.![]()
Is this true?
BTW - I plan on getting Vista in soon so I can play Halo 2 Vista, I've heard the Vista drivers are pretty rubbish for these cards. True? Should I consider something else?
squiffy said:Problems were to do with Dell shipped X-Fi's, no internal DD decoder.
Yes, Windows XP.
Buffalo2102 said:Don't worry about it. Most of the Vista driver gripes are from audiophiles who have lost a fair bit of the functionality they had under XP. The current drivers are perfectly adequate if all you want is good quality output sound. My X-Fi works fine and is still a cut above my Realtek on-board sound.
Since Halo 2 is Vista-only, you can't really consider XP can you?
I am running Vista x86 and have a X-Fi Gamer - I have no problems with it at all. Works great for Halo 2 as well.
Having said that, I wouldn't recommend that you rush out and buy one as there are plenty of alternatives available and you should research all options.
james.miller said:good for you buffalo, because my x-fi gamer isnt picked up at all in vista 32bit![]()
most of the complaints are for poeple who cant get the cards WORKING in vista, never mind loosing a little functionality.
MeatLoaf said:I had an X-Fi gamer and it was fine in vista![]()
snazzy_dazzy said:tbh I cant notice any difference between my old asrocks onboard and my xfi xtreme music.
