X-Fi XtremeGamer Fatal1ty & Logitech Z5500
11 Mar 2007
Bought the above today - getting delivered tommorrow.
Whats the best way of hooking these things up to one another? I take it DTS and EAX can only be used with digitial or coax? What cable do I need as I dont think the Fatality has a digital output on the rear?
Thanks in advance!
Just use the orange, green black wires, i have the same set up as you, if you have the speakers in direct mode you can get EAX that's all down to your sound card.
I use optical for my 360 (can't use this on the x-fi nor coaxial unless you get an adapter)
As for DTS i don't know to be honest, i am assuming the sound card sorts that out, saying that, at the moment running 'direct' top right of the console display says 96..24, and at the bottom on the console the logo says DTS 96.24 so i assume+ its running DTS at the moment.
Either way sounds amazing :D
thanks for that - I have heard good things about that setup and I have got the entire day to play around with a load of new games and no missus moaning!!!!! RESULT
