X1600 Pro Or 6600GT?
18 Aug 2004
Leeds, UK
My current card which is a 6600GT keeps overheating so I am looking at buying another one, for under £100. I found a x1600 Pro which has 512mb of ram and a 6600GT which has 128mb of ram. The 6600GT served me very well and ran games like BF2 and FEAR no problem at all, but I am tempted at going for the x1600 Pro due to it's amount of ram. Is ram that important in games or should I be looking for something else such as clock speeds and pipelines?
hi
i've put 2 computers together 1 with a x1600 agp and 1 with a 7600 gt pci-e and i think the 7600 is slightly better but both very good cards or if u want a real bargain get a 7300 gt there great for the money
geordiepaul said:
Why not just get a better cooler for your current card?
Because even with a big house fan on it at full speed it still overheats. It's that hot I can't even touch it without getting burnt.
EDIT
AGP Only as my board don't support SLI/PCI
LoadsaMoney said:
6600 GT is much better than an x1600 pro, the x1600 pro is atrocious, and the 512mb is wasted on it, you would be downgrading. :eek: :)
But the specs on the X1600 Pro compared to the 6600 GT look much better, plus the x1600 is a much newer card.
Doesn't make a difference, the 6600 GT whoops it. :)
I would link you to a very good review which shows this over at Guru3D, but they are down till the weekend as moving servers. :(
To much porn that affecting the old eyes, i thought they had been hacked. :D
Cheers for that, has made me change my mind about the 6600GT now, It was a good card when I had it but I think it was when I had a power surge which had blown my PSU, it must have done something to the card causing it to overheat. I am not really bothered about these new high end cards, tbh I can't afford it at the moment so thats why I happy with a mid range card.
For a hundred quid or so you could get a cheap PCI-e motherboard and a OcUk 7300gt with DDR3 which would outperform both the X1600s and the 6600gt by a fair bit.
If you've got enough for an AGP X1600 pro, then you've got enough to upgrade from you 6600gt.
Have you had a look at the card for any physical damage. The Buck/Boost converters that convert the PSU input voltage to one the GPU and memory require should provide a buffer to save the chips set, but the components around them may be damaged as a result of the surge, this may be visible damage.. e.g. blown capacitor. It may not help with a fix, but at least you'll know what is wrong.
