Hi
Anyone know why my pc reboots when it gets to the end of loading the bar in farcry, but say if I turn up my new X1800XTs fan speed using ati tool or something.. this doesnt happen. I have had artifacts in farcry that I fixed by turning up the fan speed as well. Something tells me its to do with temperature
but I thought it should turn itself up if it gets too hot which is weird
Will a zalman VF-900 fix this as I was gonna put one on the card?
Thanks
its stock clock and C6.7
Thanks
who came up with that idea
Possibility of 2 x 120mm rear fans and a 80mm on the vga duct if you use it for blowing or sucking air close to the vga and its not as if its got a pentium in it to heat up the case air
