X1800 XT drivers recommendation
7 Apr 2003
Hi,
I was wondering what the best ATI X1800 XT drivers where just now? Should I be using the Omega ones or the standard Catalyst ones?
Also, what kind of overclock can I reasonably expect on the X1800 XT?
LoadsaMoney said:
Official 6.5's here to, working great. :)
Loadsa - sorry another ccc query :D. I take it if your using ccc there no way to dictate the fan speed depending on temperature. It all automated and i couldn't quite see unless i use atitool or something.
If i opt for that then i to disable the 2 services that ati have is that right? Cannot remember what the service names are. :confused:
Yup, get ATi Tray Tools, that has the built in GPU fan controller.
Can't remember off hand, but these 2x ring a bell for something.
ATI Hotkey Poller
ATI Smart
As said above also, ATi Tray Tools has it built in. :)
