Welcome to the forums.
Yes its normal, mine does it, everyones does it.
Its not the corruption he is on about, i know what it is, but i cant describe it, its after windows has booted to desktop, you know when the CCC kicks in or something, and the screen flashes, thats what he's on about i think, i hope lol.
ill reboot my machine then try and describe what mine does, but it is normal as it has something to do with the CCC.
Ill see if i can describe it a bit better now, right, you know when your destop first appears, and all your icons are loading up next to the clock, the screen will flash blank for a second or so as the CCC one kicks in.
Well thats what mine does anyway, but as said it is something to do with the CCC kicking in, and is perfectly normal, so don't worry about it.
Hopefully theres someone out there who knows what im on about, as im crap at describing things in type, and can verify it as it will happen to theirs.
