Graemebo said:I see there is a 1900GT is that a good or bad card beside the X1800XT.
I want to at least be able to play latest games smoothly it doesnt
always have to be max detail, and wont be going over 1280x1024
And can anyone recommend brands or are they all much the same
Graemebo![]()
Theres actually a x1900gt cardzytok said:a 7900GT is pretty much on a par with the X1800, better in some things, not so good in others. Either card should do you proud at 1280x1024 with pretty much everything turned on in pretty much any game out there for under £200.
t31os said:I'm running a 256mb at 1600 x 1200 with no problems, battlefield 2 maxed out.
I'm about 80% sure thats more down to system memory rather than graphics memory, everygame thats basically happened to me with disappeared when using loads of system ram.dewi said:I have a 256 Mb X1800XT. I find that, playing Dungeons & Dragons Online at 1024x768, the display stutters if I set the textures to "ultra high", even though the average frame rates don't drop. With the textures set to "high" (and every other setting maxed out), the display is very smooth. I assume a 512 Mb card would be fine with the textures set to "ultra high". If so, there are (slight) differences between the 256 Mb and 512 Mb cards even at resolutions as low as 1024x768.
Vegeta said:I'm about 80% sure thats more down to system memory rather than graphics memory, everygame thats basically happened to me with disappeared when using loads of system ram.
