X1800XT 512 voltage question.
Permabanned
11 Mar 2004
can someone please tell me the correct stock voltages for an X1800XT 512 and if possible point me towards an easy overclocking guide for the X1800XT`s i found the one on here for the X1900`s but its far from simple and there are some differences with the X1800XT model.
stock voltages are 1.275 for 2d mode, and 1.4 when it switches to 3d mode.
overclocking all depends on weather you use the ATI CCC or not, but from reading the x1900xt guides overclocking a x1800xt is the same as a x1900xt.
