X1800XT Help
18 Jan 2004
Sunny Scotland
Right guys just built my new system but i am having a problem.
The graphics card does not reinitialise if i restart the pc or just try and boot it up...i have to switch the psu off at the back and then leave it a min then it works fine...not played games for a large amount of time but bf2 was fine for 30mins.
I have a asus A8N-SLi Premium nForce4 SLi and the gcard is PowerColor ATI Radeon X1800 XT 512MB GDDR3 AVIVO. Have a antec neo 480 so plenty of power and the card is on its on power cable straight from the pc.
Do you think itwill make any diffrence if i plug it into the asus EZ plug on the motherboard instead of the psu?
other wise gona have to rma :(
I'd give it a go at least. As long as the fan's not a 120mm or anything large it won't burn the mobo header out.
you need the GFX card powered with it's six pin connecter as suppied with it which in turn is connected to a HDD molex
the EZ plug is to SUPPLY power to the mobo not to give out power ( that why its a male one not female
yes plug in one of your spare molex HDD con.s into it
yeh i have the fancy connector thing connected to the gfx card, so I should also plug in a spare molex into the motherboard correct ?
Yeah that spare molex does connect to the mobo man! I had the same problem when I was changing the PSU and forgot to put it in.....whoops :P
