X1800XT or X1950pro, which is faster?
21 Oct 2002
Bexhill on sea
As title. both cards are 256 meg, so I was wondering which of these two would be the better card? obviously the x1800xt would be s/h and the x1950 would be brand new.
Cheers
I know which one i would pick, the X1800xt , as its mine !! :rolleyes:
but on a more serious note, they are both reasonable cards, i would say in my opinion the X1800XT holds its own against the x1950pro, only cause i was dissapointed when i moved to a X1950XT-X, making my x1800xt redundant, I didnt see a huge difference :( thought i had wasted money really
it was the leep from X1950XT-X to 8800GTs that i really noticed
About par with each other. In Benchmarks the X1950 Pro will be faster due to it's 36 Pixel shaders. However, The X1950 Pro has lower clock speeds and 12 Pixel Pipelines compared the X1800XT's 16.
If I were to take an educated guess, I'd say the X1800XT would be a touch quicker, but there wouldn't be much between them.
Mul
the cheapest you can get. personally, i have the x1800xt and ive clocked it to 700core and 800memory so its faster that the x1950pro.
so, get the cheapest. possibly a x1800xt with arctic cooler if you can
x1800 XT , i know its says the 512mb x1800 XT there, but the 256mb is the same performance, id just get the x1950pro though seen as its brand new, as the x1800 XT is only faster by 10-15fps. :)
Id say the x1800xt WILL be faster but 10-15fps i doubt that theres little in between them id say 10 fps at the most.
