x1800xt (pe)
22 Jul 2004
North East, Cleveland
hey all, I have a x1800xt flashed to a PE which i need to reflash back to its default bios, but i cant find the old bios or the program to flash it.
Any help ?
Cheers
Id do a google search for the sapphire x1800xt bios, depending on manufacturer of course. Should your old bios not be saved in the directory of the FLash Program though? Thats if you made a copy
cheers for the reply, i dont even no if i still have the program, i have a totally new pc now and i dont think its on my HD.
hey guys cheers for the replys to far, ok so iv managed to flash the bios from the list posted, but....but i think iv flashed the bios to the same clocks it has already has, Iv googled for stock bios settings but cant find much at all and i dont suppose it helps not knowing what the default clock speeds are anyways.
Any help would be great cheers
