x1800xt problems
19 Oct 2004
London
Get myself a new graphics card and the first thing i wanna do is try out some games...
Now HL2, Day Of Defeat all the source games keep crashing when i try and adjust all the settings to max
and now when i try and bench with aquamark i get this error message
TERMINATION: Exception Caught
Code: EXCEPTION_ACCESS_VIOLATION
Info: The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
Flags: 0x00000000 Addr: 0x0fe9266a
eax: 0x00000001 ebx: 0x1e3b03a0 ecx: 0x00000001 edx: 0x00000091
ebp: 0x0012f954 edi: 0x00000091 esp: 0x0012f940 eip: 0x0fe9266a esi: 0x0012f95c
segc: 0x001b segd: 0x0023 sege: 0x0023 segf: 0x003b segg: 0x0000 segs: 0x0023
can anyone help?
ok i've found this post somewhere else which seems to fix it, but i don't know what it means. Anyone?
"fixed it... some ATI cards need an updated direcpll to work"
this is the error message i get in HL2 etc
"failed to lock index buffer in CMeshDX8::LockIndexBuffer"... (engine error)
also when it detects my auto settings for graphics it's telling me i want to have tilinear filtering on instead of x16 - which is what i want.
ideas?
Aquamark needs an updated file as I think he has already mentioned.
That error I have also recieved in HL2 using a X800XTPE and an X1800XL, are you running Adaptive Antialiasing by any chance?
I found using that seemed to coinside with the error. Have a play with it :)
As for the auto check settings, I believe its just source not recongising your card as being powerfull. Would be interesting to see how It works it out.
Hedgey thats exactly what happens to me, then i get the error message
thanks Mekrel
do you know what file i need/what to do with it?
Adaptive - yeah, i'll turn it off and try again.
i'll let you know how i get on
man, am i gonna have to stop using Aquamark now.
i've looked all over for somewhere to download the dll file and all the links take me back to aquamark.com - which is an adsite :mad:
i was really hoping to beat 100,000 with my new card...
nice one hedgey, i'd almost given up on that.
good news is i've let ati overdrive do it's thing, an my card is happy at 690/800 :D
9730 in 3dmark05, will let you know the aquascore when i get it.
One other thing, did i read that you can mod the volts on these 1800s with software? And did people ever get past the 690/800 barrier?
i know there's the PE bios knocking around but that ramps the volts from 1.2 to 1.4 doesn't it? bit of a big jump on stock cooling...
Dave... I *think* the XL voltage is 1.2, where as ** card voltage is either 1.35v or 1.4v (think its 1.4v - opterons voltages are 1.35v :P). The PE bios for you should only change your clocks.
There is some software which lets you modify the voltage - its normally on peoples screen shots :)
And another thing, both me and my bro are getting corruption on the Lanparty start up screen, with this new card - anyone else getting that as well?
i'm running the 6-23 bios and 6.1 cats... :confused:
If you mean the picture that comes up then yes, its normal, happens here on my LanPartyRDX200 Crossfire board, it looks about 8x colours lol, i just disabled it. :)
ideas?
Thats happens to my X800Xt PE, think its the new update, never done it to me before.
Happens to me with my Ultra-D as well, got an X1800 XL, so i think it must be something with the latest range of ATi cards :o
Yeah i thnk theres a BIOS for my board that fixes it, but i don't see the point, its only a picture. :D
