- 12 Feb 2006
I just ordered the above card from OcUk (you know, the one at the top for £235), and i wanted a heads up on the temperatures i can expect. I'm contemplating buying the Zalman GFX Flower Cooler, but i wanted to check before i fork out the extra £40, if the stock cooler is any good?
I have good case circulation with a massive Zalman flower CPU cooler that actually cools half my PC xD, two 80mm's at the back, and soon to be a 120mm at the front.
Thanks in advance chaps...
PA
PA
), take my old card out of it's slot, Put the new card in, screw the screws, install new drivers off Installation CD, play.
You meen the 256mb is faster than the 512mb in 1024x768? Me don't think so
