- 17 Apr 2006
- Hampshire
Hello all,
I've replaced the cooler on my x1800xt with the accelero S1. In the persuite of silence I ran it passive. I then loaded up ATI tool for a stress test and was slightly conserned at the voltage regulator temp. It rose to 113 degrees C.
I've asked AMD Customer support buy they don't have access to the thermal limits for this component. AMD have chosed to keep that information private.
So, gurus of graphics hardware, what's the hottest you've run the voltage regulator on an x1800 or x1900 series card for extended periods?
Smile,
Chris.
Smile,
Chris.
