X1800XT Voltages on Water & Temp question
Caporegime
8 Jan 2004
Rutland
Just acquired a nice x1800XT 512mb, running under 40 degrees load with an AquaXtreme MP-1 waterblock and BGA ramsinks.
Now before I start messing around with the clocks, I wondered if anyone has played around with the voltage options on this card, and if they saw much benefit.
Another quick question too, the voltage regulator temps, without the HS on mine, they start to warm up, hitting around the mid 50s, what are their temps like on air?
I'm hitting 9.2k in 3DMark 05 with the card at stock and my CPU at 2.8ghz, that sounds like a healthy score to begin with doesn't it?
10 Apr 2006
Southampton
got my x1800xt 512 to 695 on the core / 795 on the memory at 1.425v for 42'c load on the core and 46'c load on the memory (without ramsinks).
thats with a switech MCW60 block.
didnt go any further due to my 3200+ and 1GB of crappy ballistix, but I expect I could with a nice opteron and 2gb score well over 10.5k in 3D05.
Caporegime
OP
8 Jan 2004
Rutland
sablabra said:
The score sounds just about right :) . My x1800xt 512mb responds very well to voltage, hence why I hit well past 11,2k in 3dmark 05 :D
What voltage are you running at, and what kind of speeds are you getting mate?
Thanks for the help :)
Caporegime
OP
8 Jan 2004
Rutland
Is that 1.425v on the GPU or mem mate?
17 Dec 2005
My 24/7 speed is 760/864, gpu at 1.495V. At 1.525V I hit around 780, but it tends to hang after a few hours of playing, so I keep it at 760 and 1.495V, which is stable
Caporegime
OP
8 Jan 2004
Rutland
Thanks thats really helpful, have you played with memory voltage at all? Just trying to gauge what values I should be playing with before I get stuck in.
10 Apr 2006
Southampton
no Ive not yet.
i have some of the swiftech BGA ramsinks, but Ive to stick them on with some thermal epoxy as the tape that was already applied to them wasnt good enough to stick em!
I hope to able to afford an upgrade to an Opteron 165 and 2gb of mushkin memory soon, so I will them be able to start really overclocking the system and get some nice 3D05 scores.
17 Dec 2005
I've lowered the mem volts a bit. I found someone who have really tested it thoroughly. Check this out:
GPU
1.425-1.45v = 756mhz
1.475v = 762mhz
1.5v = 783mhz
1.525v = 789mhz
1.55v = 796mhz
1.575v = 803mhz
Mem seems to have gone from
2.097v = 909-936mhz
1.933v = 945mhz
1.949v = 954mhz
1.955-1.965v = 963mhz
1.979-1.987v = 972mhz with slight artifact in 3dmark05 GT3
Caporegime
OP
8 Jan 2004
Rutland
GPU
1.475v = 762mhz
1.5v = 783mhz
1.525v = 789mhz
1.55v = 796mhz
1.575v = 803mhz
2.097v = 909-936mhz
1.933v = 945mhz
1.949v = 954mhz
Less memory voltage gave better clocks? How strange, I wonder if thats a temp thing or if the ICs actually respond better to less voltage.
Permabanned
17 Aug 2004
Pencoed
Jimbo Mahoney said:
Found a hardmod on XS. Not sure I have the, er, spheres to hardmod a card this expensive though....
I'll do it, send her over hehe ;)
with my x1800 i used max volts on the core.
Didnt mess with the mem too much.
only had it for a week or two but had 11.5k in 05 out of it so they clock very well.
Tom
17 Dec 2005
Better with lower voltage, yes :) . It's definitely not because of temps...
6 Nov 2004
Mine crashes in game at 1.5V it doesnt even show artifacts it just crashes, could this be because the msofets or something are getting too hot? I'm on air cooling so I think 1.5V maybe too much because I dont have a cooler for the mosfets etc normal crap one.
17 Dec 2005
Minstadave said:
Just been having a play with my mem volts and have got down to 1.875V and still finding the memclocks improve as I reduce them :confused:
Really? That's interesting, I have to try that out. I haven't played with the mem volts a whole lot. Btw, do you use ati tool for overclocking? I do, but whenever I start a game, the screen turns black, and I have to restart my computer. The only way to make it work is starting the game without oc, and after it has loaded I can oc again. :confused: Any solutions to this???
