x1800xt - what overclocking tool?
15 Nov 2005
Newcastle
Ok, my agp x850xt is up for auction as the same model is going for £180+ used :eek: Thats more than new! So anyway, ordering an X1800xt 256mb, 3700sd and new motherboard on Wedensday and was just woundering what overclocking tool people are using to clock these cards and set the fan speeds? I don't like using the CCC Overdrive and have been using Ati Tray Tools for the x850, so will it work just the same with the x1800 or is it not fully supported??
Many thanks
The X1800XT is not supported by ATI tray tools or overclocking in ATI tool. (anyone who has tried has reported major stability issues).
Also CCC overdrive limits the overclock on stock volts.
I use a combi of ATI tool for voltage adjustment / fan control and X1k overclocker for the actual clock adjustments. (some reports are that this loosens the memory timings however users over at XS have stated it doesn't - meh works for me).
You have to manually type the clocks in the 2d pane (not 3d).
