Hi,
This is an issue which I was investigating as part of the "Asus A8R32MVP" thread. I know a few other people are also having this problem, so I thought I would start something seperate off.....
Anyhow. The story so far.
When cpu usage is high, I get a "ripple/wave" type interference effect on screen, most noticable on large areas of lighter colour.
I raised a problem ticket with ASUS - heard zip from them.
Raised one with ATI. They gave the usual "make sure you have a psu that meets the requirements" standard sort of reply. I'm using an (ati approved) FSP Epsilon 700w psu so thats not an issue...
So I persisted, and after a few emails, diagnostic reports etc later, they have come to the conclusion that its a fault with the Crossfire card - or a "tollerance issue" as they put it.
I did a few further tests, and it also has the problem when the crossfire card is used on its own - so its not likely to be a power rail issue on the psu, as I tried both pcie power connectors. Also both PCIE slots as well.
Just for completeness - I am using a 21" CRT, with a DVI-VGA adapter (so using an "analoque setup" as ati put it). Tried another couple of adapters - same problem. Using the same monitor and adapter on the "normal" x1900xt, and the problem is not there.
So it would appear to likely be an issue with the section that merges the card outputs (or the strange hd-dvi cnnector thingy?) specific to the crossfire card (or the crossfire card is just from a bad batch?).
ATI Recommended I return it for a replacement. Its a HIS card though, so I will have to go through either OcUK or HIS - anybody know which one I should use?
