- 27 Jan 2003
- Chesterfield, UK
Hi,
After my last post and not having anything definitive I decided to buy one and see/listen for myself. Bought a Sapphire X1900XT.
Currently Reserator Cooled and Running a GTX 512 with the heatsink.
Like a few people have stated startup speed is very noisy and although its loud its not a shreaking loud. This quickly slows down to a quietish hum. Louder than the GTX 512 but not buy much. Next thing to do was run 3D Mark 2006. Test run at default XT speeds. Running the test increased fan noise but the noise wasn't too bad and at XT speeds never seem to get much above stage 2 of the fan. Unlike the GTX 512 where there seems to be a totally varible fan the X1900 seems to jack the fan speed up in stages. Cranked the Card to XTX speeds and the noise increased to the 3rd level of the fan which was some what louder while running the tests and produced temps between 87-90'c via the overdrive panel. Not sure if this is a tad high ?
The 3rd level noise was quiet high certainly higher than a GTX 256 but the noise was not harsh.
Anyway I'm pleasently suprised by the noise and although louder than the GTX 512 it isn't a Dust Buster by any means although the potential is there if the thing got to hot, probably put it back to XT speeds for the noise aspect.
Performance wise in 3d Mark 2006 My GTX 512 is faster scoring nearly 5800 against the XTX score of 5481. Off to play a few games.
X2 4400 @ 2.64
2 Gig of Ram
XTX Speeds
3d Mark Score 5521
SM 2.0 Score 2193
HDR/SM3 2372
CPU 1865
X2 4400 @ 2.64
2 Gig of Ram
XTX Speeds
3d Mark Score 5521
SM 2.0 Score 2193
HDR/SM3 2372
CPU 1865
