PinkFloyd said:Depending on your definition of fine you won't have a problem.
The 8800gts isnt a huge boost over the 8800gts in some games.
Willbo said:How does the BFG GeForce 8800 GTS OC 640MB rate? It's been recommended to me a few times.
Probs would go for the 640MB at that res, I'm quite lenient with my games, if there only played SP I'm not bothered so much by frameratesWillbo said:I don't know about everyone else's definition, but I'd like games to run smoothly with no jumping or anything, and to be able to make the most of the 24" monitor by running at max resolution with most of it not all the options turned on including AA etc.
Willbo said:...also future proofing.
eracer2006 said:my 1950xt will run anything at max really. why buy a dx10 card when dx10 isnt out, and when it is you lose 400 quid because a geforce 8800 will be the equivalent of a 7600GT ?
LoadsaMoney said:As everyone is buying them for their Dx9 performance, no ones buying em for Dx10, your gona lose £400 lol, sorry thats just rubbish, you'll easily shift an 8 series for a decent price, can't say the same about an old tech x1950 XT though, can't even shift those now, brand new or 2nd hand they aint shifting.![]()
