Heya I am really confused by this one.
Played BF2142 yesterday everything was fine. Come to play it today and it got loads of artifacts on screen within a minute or two and quickly exited. Looked at temps and they were 80C, normally only get 70C max with my Accelero X2 and thats when my room is hot. Everything else is fine. CPU at 38C and mobo at 44C (this board runs hot anyway and so gives false mobo temps).
Took the card out and no dust on it or anything. Put it back in same problem. Only difference between today and yesterday is that I have the AMD (ATI) 7.1 drivers. I also have newest version of Traytools with standard speeds.
I really cant see why its running so hot! Fan is reaching the normal 2000rpm so thats working fine. Seems the GPU temp increases very quickly, but environment temp doesnt differ from normal.
But when idling is sitting at 55C which is normal in my case for 2D speeds.
Does anyone have any suggestions?
