X1900 XT-X
17 Jun 2004
I have a sapphire x1900 xt-x first of I can't seem to get ATI CCC to work. I have net framework 1.1 and 2.0 according to add/remove hardware. So not sure why its not working.
Second off ati tool, 0.25, everest and ati tray tools all detect gpu core as 500 and memory at 600. Now I know this is not right at all!
In ati tray tools it says bios gpu 500 and bios mem 600. Now is this gpu bios or mobo bios? If its gpu bios is there a way to flash it?
Also in everest it sees the card as a X1900 XT :S
Well the box says x1900 xt-x as did the stock heatsink (replaced with accelero) so not sure whats going on.
Anyone have any ideas?
your card has two clocks, 2d and 3d, higher speeds will initialise when you open something 3d...
also get rid of CCC, stick to try tools
