X1900 XTX temperatures and fan
What sort of temperatures are your cards running at when under full load - what should they be. I ask because I was having problems with overheating due to the lousy job Catalyst Control Center performs controlling the fan speed. I have had my card for 2 weeks and twice in this period has the overheating alarm come on while playing Oblivion.
The fan speed appears to be all or nothing. The temps were climbing over 90 and only then would the fan speed increase. I have sorted this out by deactivating the catalyst control of the fan in the windows services - Ati polling (something like that) I have installed Ati Tool and have manually set incremental fan speeds based on temperature. When installing Ati Tool make sure that you set the correct clocks and voltages for your card as they will default to the lower 2d settings. My full load temps have been lowered considerably so I have overclocked the card to 680 and 1590 with temps maxing out at 71. The fan is louder but it is not really a problem as my PC is fairly loud anyway and I use closed headphones.
