X1900XT 512 Clocking
12 Jul 2005
My my, i was pleasanlty surprised yesterday - i am now running at 668 and 798 clock speeds on air. HOWEVER - there has been no change to any FPS in any game and also my 3dMark 05 score has dropped 200points - er - wtf? im using CCC and have run the automated clocking utility - which gives those results. Do i have to do something in particular to 'turn the results on' as it were? im confused - i have ati tray installed too but havent used it yet.
Can someone please explain why i get great clocks and NO results and if i have to do something in particular to get them to work?
cheers
cheers
I also get the same, I loose point in 3d mark 06 when I push my card to the max.
715core and 870mem is no faster than 695core and 830mem.
I use ATI Tool not CCC.
Got an artic coling x2 cooler on it.
I normally disable the ati stuff in and don't use CCC at all and I've set all those sliders to high performance.
If i remember rightly @ 695core and 830mem I get 6250 3dmark 06 and with it clocked any higher it'll score less ? weird I know !
Highest I've run was 720core and about 870mem ! with only mild volt tweeks,
think it didn't even score 6100 on 3d mark 06! get loads od graphical glitches if the mem is over 860mhz.
PSU is a Corsair 620hx so power isn't an issue.
well i guess that when i get home ill get rid of CCC and then try just using Ati Tray Tools - ill see what happens then - i used to be able to clock the card when i had CCC and no Ati Tray tools installed so it could be a confilict between the two peices of software - i dunno - anyway - ill update once ive done it - cheers for the advice - roll on 5:30.
