X1900XT Crossfire Settings Help
29 May 2005
Lads,
can any owners of an X1900 Crossfire setup please confirm what settings you use in the CCC..
BF2142 and Just Cause only hit the heights of 30fps or so (both running at 1600x1200 with No AA/AF) when Crossfire is enabled, but ramp up to 60-90fps when disabled (as in the master card doing all the work).
Haven't tinkered too much with the settings in the CCC, but I always assumed you don't go near the Catalyst AI tab as per instructions.
i.e. Have always just left the Disable Cat AI box unchecked and the slider at standard
Can any lads confirm what settings give best results in games such as the two above.
I can't believe that its a general issue with the setup as the system has no problem hitting 10400 or so in 3DMark06.
Cheers
P.S. V-Sync is disabled before anyone suggests..
