X1900XT fan problems...
25 Jul 2006
Taunton
Recent purchased a Powercolor X1900XT 2nd hand, straight away put a vf900(fatality) on it, found out that wasnt good enough to cooler so put the stock back, that brought down temps loads...
now my actual problem is that when using ATiTool or ATiTrayTools to set the fan speeds they dont seem to work, for instance core is @ 40oc, i've set the fan speed to be 36%, though its at 63%. no matter how many times i load it or another profile with fan speeds they never seem to go to the right speeds and sometimes the fan will completely stop altogether.
not a clue why its doing it :confused: can anyone shed any light on this.
