x1900xt HDCP?
8 Jan 2005
Macclesfield
How can i tell if my x1900xt has HDCP support? I know there was a whole ati HDCP fiasco and everything
Basicly ive just bought a 23" HDTV and want to run my pc through a DVI->HDMI cable and was wondering if theres anyway i can check it will work?
Cheers
I have a 1900XTX and get 4 reds in the bottom ones. Despite having a 2407 that is HDCP compliant it says it isn't but not fussed about that, I know better and I knew the card wasn't compliant anyway.
/EDIT. just re ran it and it now says only the bottom 3 are red. Go figure......
