X1900XT not switching to 3D clocks when playing WOW
6 Jan 2006
Plymouth
I subscribed to wow again the other day and I noticed that I am getting fairly low framerates than what I remember it use to be like so I looked into it and I noticed that the core and memory clocks are staying at 2D speeds when the game is running. I wanted to see if this was happening with other games so I ran the Stalker beta and it was working fine. I have tried both the 7.2 and 6.8 drivers but its still the same.
Anyone have any ideas on what is going on?
Ta.
as said - 3d clocks on fire up in fullscreen 3D. if your running windowed, it will sit on 2D. then again, wow works fine for me an an X1800XT 2d clocks with 1280*1024 max details 4x fsaa.
also note that if you minimaise a fullscreen app, the cart will almost always drop to 2d clocks again untill you re-maximise the app
Yes, I do run in fullscreen windowed mode so I guess this is the reason why its happening.
Thanks for the help.
