x1900xt problems with non dvi monitors
1 Nov 2003
Maidstone, Kent
Hi,
I've recently purchased a HIS 1900Xt mastercard.
When running my Dell 2405 (via dvi) I have a perfect picture.
However, if I attempt to add a second monitor once I enable it via settings, the display works, but has a number of darker horizonal lines which kind of flicker on it.
They are hard to see on dark backgrounds, but clearly visible on lighter ones.
I thought it was the monitor, but have tried a different monitor and still get the same effect.
Both of the tfts I tried only have non-dvi input? Is this the problem or something else?
Many thanks
Hussman said:
Hi,
Many thanks
I cant believe that its anything particular to input to vga ( unless its the particular cable or dvi-vga converter you are using) did you use different cables with each monitor or a different converter ( as I am guessing card is dual dvi)
