- 1 May 2006
Ok, spec one has 2 X1900XTs X-Fired, cat 7.10 with Hotfix, 2gig Ram, Opty 165 @2.6ghz, 1440x900 rez.
Spec 2 has 1 HD2900XT at stock, 2gig Ram, cat 7.10 with hotfix, E4300 @ 2.7ghz.
Spec 2 seems to get nearly double the FPS of spec one
Both systems running Win XP.
Is crossfire not working in Crysis?? I've put cat AI on standard and advanced and still no joy in performance increase.
Any suggestions, advice, or knowledge on the matter would be appreciated.
Update: It seems if I disable Crossfire I get better performance that with it enabled. So much for the Hotfix ATi brought out.
.Both systems running Win XP.
