Traducer said:Would those graphics cards be ok for cooling and power in a case like the Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU?
Traducer said:Thats sweet man, means I could buy a crappy case and psu and get a killer cpu and X1900XT/X insted of spending 200 on a case and psu, its only got to last a few months, then I will splash out on the case and psu.
Though I am still unsure, may end up going cheaper on the graphics and cpu and getting a better case and psu first time round.
Traducer said:Hehe well any spare cash after this build, its going to be spent down the pub.
I don't think there is any need for them cards just yet.
It has already been answered by Yewen. If XTX speeds are so important, buy the XTX. There is no guarantee or warranty that the XT will clock to XTX speeds, so if it does - you're in luck. Otherwise, you're not. It's that simple.Traducer said:I wish someone would answer my question about the overclocking the card hehe.![]()
Traducer said:Guys can this card be clocked to the same speed as the XT-X version easy?
PowerColor ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express)
