. I've read about people not removing the cover behind the pci-e slot before mounting the card.sablabra said:They aren't supposed to go that high, you know. You either got a bad mounted cooler, or your case temp is way too high. It's incredible how people manage to mount these cards too. I've read about people not removing the cover behind the pci-e slot before mounting the card.
LoadsaMoney said:95 is way to high, my x1800 XT only goes to about 69-70 underload, and it idles about 55, could be poor airflow in the case as said above.![]()
the_box said:my x1900xt hits 45c at load and idle at 34c
dale1uk said:could be well off the mark but are you still all running the stock fan settings?? Only asking because my x850xt's stock settings only had the fan spinning at 13% until it hit 85'c resulting in me getting similar temps under load until I checked the fan set points in Ati Tray Tools and changed them. Now it never goes over 63'c under load and the max the fan is set to spin at under load is 65%.
The Asgard said:95'c under load is about right. Mine hit 92'c while running fear and 3D mark 2006. Just google X1900 loads temps and you will find a lot of people hitting 90'c+. Even Reserator cooled mine still hit 70+ 'c. Is this a sustained 95'c?
I AS5 mine with little or no effect to temps.
The X1900 is in a different class to the X1800 with regard to generating heat but it uses the same heatsink & fan hence the higher load temps.
Shocky-FM said:Yes its sustained well in shader heavy games.. I can tell by the noise from the fan, its like having that nvidia 5800U in my rig, infact its worse... Sad that kind of cooling has become standard..
