X1900XTX overclocks
17 Jun 2005
Near Brighton
Looking into clocking my X1900XTX. Currently got an X2 4400 @ 2.4ghz but will go higher as im on water. Looking to clock my graphics card a bit as well to give me some more fps. Graphics card also on water.
Now im not bothered about clocking a huge amounts, just a small amount which is as hassle free as possible.
Is it easiest to use Overdrive in CCC?
Ok, just did the auto detect clocks in ccc.
Core came up as 689Mhz (stock of 650Mhz)
Memory stayed at 774Mhz (1498Mhz) which is stock.
2 Things. First any idea on if the cores clock any higher on xtx's. I can up the clocks, test for artifacts etc but if most wont go much higher il leave it.
Seond, the memory. Surely that must overclock a bit? Currently using ramsinks not that it makes much of a difference
