X1950 Pro users: What settings are you running under CCC?
10 Dec 2006
Hi,
Under the 3D tab on the CCC there are various settings like AA, AF etc.
What settings are you running? Wondering what to set myself!
Thanks! :)
The icon bottom right of screen where clock is. I just set to quality or high quality depending on game. I dont mess about too much in ccc.
mishima im using standard setting I have not change a thing in CCC
And I'm more than happy.
beast can you monitor GPU temp in ATI tools?
Im new to using that and I cant remember seeing it.
numbster
V-Sync Off for all games apart from Pro-Evo because it is most apparent in that game. 4xaa, 8xaf for everything else, unless i know i can get away with more, such as for games 1+years old. Everything else on Quality settings and not performance apart from if benchmarking. :)
In most games you can alter the AA and AF actually inside the game, does altering the AA and AF on CCC or ATT force it to the settings you choose? eg. 4x.
Yes, and usually provides better quality and less of a performance hit than using the ingame settings, and you know that it is 99% guarenteed to work forcing it via the ATi driver. :)
