I'd thought i'd have a little tinker with my new setup. As the title says, I have a sapphire X1950 pro 512mb and used the ATI CCC and the overdrive function.
I upped the core speed about 10mhz and the screen started wobbling and distorting. I set back to default and tried upping the core the minimum amount from stock 580 mhz to 587mhz and still got the same problem.
I have a 500W PSU in my raidmax case and have the correct power going to the card and motherboard.
Do i have a card that can't be clocked at all or am i missing something ?
Good luck though man
