It seems the fan on my ATI Radeon X1950XTX has failed.
I fired up Gothic 3 earlier and it was running stuttery then locked-up my PC. Strange, I thought, but it was the first time I’d run it and it’s a notoriously buggy game. Later, after a bit of 2d surfing I fired up Team Fortress 2 and the catalyst centre kicked in informing me that the video card was running hot and that it would reduce the clock speed. It has never done this before.
I fired up ATI Tool and, sure enough, temps of 105. I went to fan control and tried to force 100% fan speed. Normally this sounds very loud but I heard nothing. So I took off the side and restarted the PC. Sure enough the fan had failed and wouldn’t start at all even during POSTING.
So to my dilemma. Is it worth replacing the fan & cooler on the X1950XTX? Do I run the risk that I’ll put a new cooler on it and find that I’ve already damaged my card by running it for a short time in 3d, and a long time in 2d, when the fan was dead? I’m also worried that maybe the card has failed and wouldn’t drive any new fan? (In all likelihood a new fan & cooler should work though, shouldn’t it?)
The other option is to buy a new card. I’m running an ASROCK 4CoreDual VSTA motherboard. This means I can’t run a 8800GT (incompatible). I think the best cards I could run would be a 3850 or a 3870.
I’m a bit skint so the new aftermarket cooler is perhaps the best route. Is the X1950XTX cooler particularly hard to replace – it certainly looks it. I want to avoid throwing good money after bad.
Any advice gratefully received..
