not very similar at all really.
I've currently got an ATI x1950xtx and I've been offered an HD3850 (single slot) for £30.
How do these compare?
Basically, should I do it?
Thanks,
G
p.s. I'm on XP pro not Vista. It's for COD4.
At 1280x1024 I get better min FPS with everything set to max on COD4 than my brother with a overclocked 8800GTS 512MB vs my X1950XTX overclocked. Same systems in other respects, it's the smoke that kills his 8800GTS with 4xAA.
I don't know if it makes any difference but I play at 1680x1050.
So if I pay £30 for this....how much should I be looking to get for the x1959xtx and should I leave my Accellero on there or put it on my new card?
Thanks,
G
I just sold a X1950XT 256MB for £35 on MM, and I think I could've got £40. I wreckon £60ish on the bay.
Mine's the XTX with 512mb on![]()
That was just a price reference for a similar card.CoD4 smoke kills the G92. I had a voltmodded 8800GTS 512mb and actually preferred my overclocked 3850 to it for CoD4. As soon as you put on anything past 2xAA with the 8800GTS frames went to the floor as soon as smoke grenades were thrown or airstrikes called.
I could run the exact same settings on my 3850 and get nearly double the min fps. I've said this on a few occasions but people usually just dismiss it as fanboy lies or something.
