X2 3800+ STAYS AT 30-33C WITH 5220 rpm fan
2 Feb 2006
Chepstow, Wales
Hi,
regardless of my cpu fan being one that will run at 5220 rpm(flat out), or one that runs at 2400 rpm flat out the temp stays the same(while not really doing anything)and at around 45-55c under load.
:confused:
Anyone have any thoughts on this?
That certainly seems a bit high. Is it overclocked at all, as this will change temps considerably depending on VCore settings?
Mine has a Zalman CNPS9500, which does 28/29C idle and 38/39C 100% on both cores (I keep it at this with Folding@Home) - this is OCed as well. What cooler do you have? Thermal compound? Case fans?
I looked at wrong temp before its actually 41c idel :eek:
I'm running it at stock with the retail HSF granted I have no case fans at the moment but do have one side off
