- 17 May 2004
Just wondering if they are sposed to run quite cool? Mines running at 27oC just after a lengthy session on DoD. Im using one of the old Zalman copper coolers. Just seems to be very cool.
that not good? or just coz it was fresh TIM?Foehammer2003 said:hmmm... my bios says 36c idle!that not good? or just coz it was fresh TIM?
Especially with it being so warm at the moment.Minstadave said:The BIOS isn't idle, you often see lower temps in windows than in the BIOS, so 36 degrees is fineEspecially with it being so warm at the moment.
) Should i see a reduction over the initial 200 hour running period? I'm using AC MX-1 atm an a G orb 2. Wanna OC soon so wanna know i'm starting off as cool as i can
