x2 3800 temps
24 Jul 2006
Essex
I was wondering the average temp for a 3800 should be at stock? Mine's idling @ 34 degrees atm but it was around 37 earlier :confused: Am I right in thinking this is a little high? I'm wondering if I put too little AS5 on. Mobo (A8R32-MVP Deluxe) temp is 31 degrees.
I just ran the sandra burn in wizard for abit aswell as running checks on Adaware and Spybot and the core temp went up to 44 degrees.
Download Prime95 and SuperPi, if you haven't already. Use two instances of these to fully load the CPU and give us the load temps. Your temps there do seem a little high, but it isn't anything to be worried about.
44c too hot?? Knock it off mate! :p
