x2 4200+ temps
16 Jun 2006
Bournemouth, Dorset
Hi need some advice......
Just whacked in my new x2 4200+, been checking the temps, and it idles at about 38 and maxs out under full load at about 53 degrees. According to speed fan my system temps are 36 degrees and pwm (not sure what that is) is 39 degrees.
Are these temps ok? will they get better after a burn in period?
Using a gigabye g power cooler pro at the mo with only rubbish gigabyte tim, do you think i should go for as5?
Cheers! i checked my heat sink just in case and it wasnt on as tight as it could be gone down a few of degrees now aswell, happy days!
