X2 4400+ overclocking
Lan
Lan
31 Jul 2006
Chester, UK
id like to see some of ppls overclocks on your 4400's i will post mine wen i receive my 4400 i basically want to get a idea on what the average overclock is on it and its stepings etc
Don't have my stepping handy but i have 2.6GHz on my 4400+ [289*9]
I can probably go higher as I have recently discovered I can up the voltage a little on my RAM, should give me some room to play with.
SiriusB
:cool: Hi,
Here is my overclock at the mo, I have not upted the voltage on the cpu yet and it runs stable at 2.5
DualCore AMD Athlon 64 X2 4400+ @ 2500 MHz (11 x 227) ;)
2.7Ghz @ 270*10, 1.45v - Mushkin Redline Extreme 2Gb DDR 2.8v Running at 1:1 - just running this in, hopefully can get higher with more Vcore. This is on an A8N-SLi Premium with AquaComputer watercooling.
Wow impressive chip! I'm at about 1.5V and reckon I could squeeze another 100MHz outta my 4400+ now the weather is much cooler.
2.8 is my target but I may have to consider more extreme cooling to get it that high as I doubt I can get 200MHz on just 1.5V
SiriusB
2.42GHz at 1.45v :( . I can only get 1.5v out of my mobo (A8N-SLI Deluxe) Tis a little annoying as one of the cores will run merrily at 2.5-6GHz at stock but the other core only does what it is doing now. Its running at 50C now at full load so there isn't a problem with the heat. :mad:
Looks like I may be joining this club in a few days or so :D . Talking to a guy who claims he can get his x2 4400+ up to 2.7ghz easily on air, and he's selling it. Gonna have to check that out :D
:cool: Hi,
CPU=Gigabyte G-Power-pro on min speed =idle temp 32c load temp 42c.
case fans = x1 140mm front intake, x1 92mm side intake, x1 120mm rear exhaust, x1 80mm top exhaust. ;)
when i recive mine (tomorrow) i will be overclocking it straight away then ill prime it and then im gon start wiv super pi etc.
