Permabanned
- 28 Jun 2006
- Midsomer Norton
I am currently thinking of buying a x2 4400 and 8i have read several forums saying that the toledo core is better at overclocking but what would be a good air cooler to use on this processor if i wanted to get 3ghz out of it.
Also what are the latest processors that ocuk have been sending out are they the ADV4400CDBOX Versions that run at 89 wt or are they the ADA4400CDBOX which run at 110 wts and wich of these is the best
Thanks
Thanks
As for air coolers,look no further than the Tuniq Tower or Scythe Ninja
The 89w ones should have a bit more headroom,mine is a 110w
. installing everything tomorrow so will let you know my results.
