X2 4400
21 Jan 2006
Seaham, Co. Durham
I got some new OCZ platinum EL ram today, 2gb. I decided to do some overclocking, my target was 2.4Ghz so it is like a X2 4800, i set the FSB to 218mhz and the DRAM:FSB is at 1:1. Temp on CPU is 50c when encoding a video using the stock HSF.firstly is this temp ok? and secondly do you think it is safe to push it any further?, any tips or advice if you think it is please.
yes the temp is fine and yesd push it further..
2.5/2.6 should be no problem with air cooling, maybe a little voltage bump to get it stabilised...
