I've never put much faith in stock cooling, is the stock cooler any good and if not can you recommend a good cooler?
I may be overclocking at some point, as I've read that 2.82GHz is achievable on stock cooling!
As far as case cooling goes, I have a ThermalTake Xaser III with the 7 fans (1 top blowing out, 2 front sucking in, 2 side sucking in, 2 rear blowing out)
