X2 4800 Core volt?
11 Jul 2003
Telford//west mids
Mine reads on the bios 1.31v is this right? (DFI EXPERT)
Cpu temp 30 c
Smartguardian also reports low cpu tem and core volt.
Ive run the cpu @FX60 speeds no problem.
yea thats about right, the lower the better at the stock voltage. It means it has better quality silicon so doesnt need as many volts to do the required speed. Should be a good clocker. :)
